VDDRN
Post by VDDRN »
Jeff wrote: Mon Dec 03, 2018 8:51 am Copy the file Config_Files/Indexed_mode/HXCSDFE.CFG from the USB Stick STM32 HxC Floppy Emulator firmware update archive ( https://hxc2001.com/download/floppy_driv ... rmware.zip ) to the usb stick root folder and rename your HFE files DSKA0000.HFE,DSKA0001.HFE,DSKA0002.HFE....
Already did, but still get the error..
VDDRN wrote: Mon Dec 03, 2018 12:00 pm
Is the stick formatted in FAT32 ?
When an image is successfully loaded by the emulator you should see the image number on the display.
VDDRN
Post by VDDRN »
Jeff wrote: Mon Dec 03, 2018 9:35 pm
Yep. I'm gonna try doing again. By the way, there was two HFE-files in the root by default, are these of any importance and should they be renamed? I tried both with original name and dska0001.hfe etc.
VDDRN wrote: Tue Dec 04, 2018 8:55 am
i don't know what "by default" means here but anyway you must start with DSKA0000.HFE file name then increase the number to add files (DSKA0001.HFE,DSKA0002.HFE...) !
And use the index cfg file from the firmware archive (Config_Files/Indexed_mode/HXCSDFE.CFG)
VDDRN
Post by VDDRN »
Jeff wrote: Tue Dec 04, 2018 9:32 am
Ah, I mean there was already .HFE files in the root folder which I didn't put there. Anyway, I tried putting the firmware on it once again, renaming the .HFE-files DSKA0000.HFE etc, putting the indexed mode-file in the root folder and still the 7 segments screen just shows "HxC" without being able to skip through any library.
Can you try another usb stick ?
VDDRN
Post by VDDRN »
Since I was able to update the firmware from the usb, shouldn't that mean that the problem isn't the flash drive? I'll try to get one tomorrow anyways and try. However, would I need to flash/bootload it and do the whole firmware thing on it then?
VDDRN wrote: Thu Dec 06, 2018 12:17 pm However, would I need to flash/bootload it and do the whole firmware thing on it then?
no since this is in the emulator.
btw have you removed all others jumper on the board ? On S0 is needed.
marfemarf
Post by marfemarf »
I want to install a lotharek sd floppy emulator into my FZ-1
Is there a step by step instruction at this point?
A consolidation of the last 9 pages on this thread?
I don't want to save old floppies, Just get right into sampling.
Thank You for any help!
marfemarf wrote: Sat Dec 08, 2018 4:14 am I want to install a lotharek sd floppy emulator into my FZ-1
Then just install the emulator and use the images present into the FZ1 quick install archive.
https://hxc2001.com/download/floppy_dri ... index.html
marfemarf
Post by marfemarf »
Thanks.
So I just put those files on the SD card and its ready to go?
marfemarf
Post by marfemarf »
Ill read the manual :-)
marfemarf wrote: Sat Dec 08, 2018 9:16 pm Thanks.
yes.
marfemarf
Post by marfemarf »
What about jumper settings on the Hxc?
marfemarf wrote: Sun Dec 09, 2018 4:07 am What about jumper settings on the Hxc?
Set ID0-A (1).
