PEAVEY SP working perfectly with HxC
Ohmen52
Post by Ohmen52 »
I just wanna confirm a PEAVEY SP Sampler working fine with HxC Floppy emulators with these settings:
PEAVEY SP (OS Vers. 1.1):
1. Plug in the 34-pole floppy connector 1:1 and the 5Volt connector only when using the SDCard Floppy Emulator.
2. Dump any PEAVEY SP floppy disk with HxC's Floppy disk dump or load a floppy image created with OmniFlop
(http://www.shlock.co.uk/Utils/OmniFlop/OmniFlop.htm) for instance!
SDCard HxC Floppy Emulator (1.6.11.16) settings:
SD HxC Floppy Emulator settings:
default
HFE file interface mode:
Auto
Hardware Jumper settings:
Atari ST/Amiga/Shugart, Drive A, ID0
USB HxC Floppy Emulator (1.6.11.16) settings:
Drive ID setting:
MOTEA
Mode:
Auto
Re: PEAVEY SP working perfectly with HxC
Ohmen52 wrote:I just wanna confirm a PEAVEY SP Sampler working fine with HxC Floppy emulators with these settings:
default
Auto
Drive ID setting:
MOTEA
Mode:
Auto
Thanks ! Can you send me the HFE file image ?
Ohmen52
Post by Ohmen52 »
I just sent you some files
part12studios
Post by part12studios »
Hi there, I'm late to this posting, but still interested in seeing if this is still an option.
I have one of my SP samplers that has a bad drive and it got me wondering if the SP has an option for a floppy emulator. Clearly the answer is yes! :)
I am curious though about the formatting? I have limited experience with these emulators.. i also just ordered one for my Amiga 1200.
Caleb
