Yamaha EX5/EX5R/EX7 is working with HxC SD floppy emulator
B_M
Post by B_M »
I never saw before any info about it and just confirmed myself. Yamaha EX5R (EX5 and EX7 are compatible) is working with HxC SD floppy emulator (I've tested rev. F).
1. You have to select ID1A on multi-switch jumper:
2. You need to use SDHxCFE_PC_1.44MB image or just generate PC 1.44MB virtual floppy.
3. Read, save and format is working:
Best regards!
User has deleted profile.
Re: Yamaha EX5/EX5R/EX7 is working with HxC SD floppy emulat
Thanks a lot for the feedback ! :D
Also interested by a video ;)
B_M
Post by B_M »
OK, later I will try to do some video...
Greetings!
B_M
Post by B_M »
I changed the surface of the panel. Instead of blue color, is polished now.
So, I have a video finally:
http://youtu.be/WBwuq3Vocx0
Thanks a lot for this nice video, i really appreciate it ! :D
