For our Arburg 220M-250-75, 156141, we're looking for the 3.5" system disks (or equivalent).
Can anyone help?
Thanks.
Arburg system disks
Re: Arburg system disks
If you have not saved the system diskette, you can only get a replacement from arburg, because the number of the loader prom on the CPU must be identical to the number on the diskette.
Osamanasar
Hello
I have an issue with Arburg 270-210-500 the problem is this machine needs the system disks and we contact Arburg but they said they don’t have this type of software any more is there any other way to sort it out
