^^ sorry I have no pics at the moment.
No the bottom mounting holes are still not tapped.
Really anoyingly the three holes on either side are & fit the OG SP1200 mounting screws perfectly?
So I have to tap them out myself & need a M3 screw tap, right?
The other option i'm thinking of is Velcro hook & loop pads.
These should do the trick & it would be easy to remove if need be.
Hardware humming on the GREY SP 1200 !
Re: Hardware humming on the GREY SP 1200 !
its a damn shamespmac wrote:^^ sorry I have no pics at the moment.
as he states here
https://hxc2001.com/floppy/forum/viewtopic.php?f=2&t=1542
when did you buy yours?lotharek wrote:Hi,
sd f dimensions are described here : http://lotharek.pl/zasoby/produkty/120/pliki/tacka.pdf
just few weeks ago, i have reduced the size to 101,3 (painted version) mm and added threats at fiting holes.
Please, contact me using CONTACT BUTTON http://lotharek.pl/contact.php - SUBJECT -- OTHER SUBJECT
keep the thread updated with what ever happens as i wanna get this done soon.
but i want to simply screw the thing in and not worry about some diy stuff to get it fitted.
I bought it direct last week, surprised holes on the bottom are still not threaded.
