Yamaha A3000 - hxc issue
r_fzv
Post by r_fzv »
Hiya - does anyone have experience of installing HXC in Yamaha A-series samplers (or the most likely similar SU700) ?
I've put a Lotharek model F in mine, used the IBM PC HD templates and it worked fine, transferring files into the machine from a PC, but now its just giving me
!ERROR: Disk read/write error. messages.
Any idea what I'm doing wrong ? The A3000 'sees' the samples in the .HFE file, but won't load/import them (and won't format a disk either).
The SDHC card (8Gb Sandisk) reads/writes fine in the PC.
Many thanks
r_fzv
Re: Yamaha A3000 - hxc issue
Post by r_fzv »
ah - sorted now. jumper settings need to be ID1A only - same as the EX5R here https://hxc2001.com/floppy/forum/viewtopi ... =18&t=1291
